Basically the bezel is held on with clips. either fingernails, if you got good strong ones, or a screwdriver. start from top where bezel meets top of dash and pull forward. work you way around. May need to tilt steering when down all the way to allow removal. Certain things may have wires attached to it, so don't rip out until you can see behind. always the radio head is mounted to inside, but the AC control can be mounted to bezel, also likely mount to dash. hazards should be mounted to bezel, more wire harness. the AC ducts will separate from insides, make sure they are lined up when installing back. Pretty simple the NEXT time you do it
