The factory brake controller will go into your 2010+ Dodge (2009 1500 only) and for those who are unsure how to get it to work with EVIC, I have the factory install instructions. It came with a full kit. (not sure of the kits part number, but the instructions sheet in each lower corner list K6861138) OE Mopar, it came with the controller, both colored trim bezels, and even the 3 small screws to attatch the controller to the dash.
To get it to work with your EVIC system, it reads:
1) VIN be must update with the sales code of the added accessory in order to enable system functionality. Using the Dealer Connect, and the wiTECH diagnostic application, complete the vehicle configuration
2) Log onto (URL deleted, I'm under 5 post)
3) In the "Vehicle Option" screen under the "Global Claims System" category in the "Service Tab" enter the vehicle VIN and the 4 digit PIN number obtained from the dealer parts dept and add the sales code(s) noted below as a "Dealer Installed Option" (I think that PIN number is XHCA)
XHC (trailer brake module)
4) Confirm that the new sales code has been successfully added to the VIN
5) With the wiTECH diagnostic application, perform the following steps from the initial start up screen
* select the "diagnostic procedures" tab
*highlight "restore vehicle configuration"
*select the run diagnostic button
*select continue
*verify the vehicle VIN is correct
*Once verified, select the "correct VIN" button
*Note on screen instructions an d select "close" button
1) Disconnect and isolate the battery negative cable
Now it just goes into the install instructions for the controller.
The info it of no use to us, but it will assist your dealer if he is not aware of this install which is sounds like most are.
