Hi guys I have been looking at replacing my stock tires, they are Goodyear Wrangler HP P275/60R20, the tires are passenger rated so I would like to replace with a actual LT rated tire. The tire in mind is Toyo Open country AT in LT305/60R20 would they fit stock wheels and suspension??
Thanks.
· If only I had more $$$
Welcome to DT
I would put a leveling spacer in the front, and depending on how close those stockers are to your top spindle,.. you might need aftermarket rims.
The other size I am looking at is 285/65R20.
I don't think the 305/60/20 will fit. Anything much wider than 11.5 hits the upper control arm on 2006 and newer rams. The 285/65/20 might fit. Only saw them on a 2006 2wd. Im going with 275/65/20 on my ram. 34" tall and same width as stock.
I had the 285 65 20 on my 2007 Ram 1500 before i lifted it and they fit just fine with no rubbing. I have them for sale if you are interested in the classifieds.
Justin
