2005 Ram 1500 stalls in idle, and whenever I stop. Was getting camshaft position sensor error code. Changed out Camshaft sensor twice, crankshaft sensor, TPS, oil pressure switch, pcv valve, sparkplugs, coil packs, a new ECM programmed to my VIN, & even changed the oil. Apparently this happens with these Rams often. Does anyone have a legit fix for this intermittent stalling?
If you own a dodge with a 4.7l that is surging or hunting and have tried all the sensors with no results, try checking the power steering fluid and the power steering fluid pressure sensor.
Related Threads
DodgeTalk Forum
4.7M posts
289.9K members
Since 2002
