1 - 10 of 10 Posts
Got one off ebay for 181 shipped. Great price. plug and play. Took me under 2 hours to install. Works great.
The only thing is the horn beeps when it starts. Like 3 times. I want to shut it off or cut the wire to the horn. Anybody done this?
Info is appreciated.
Michael
We would need to know what model remote start did you have.
were there any kind of directions with it for programming? I am sure you can turn that off but I do not know how. I dont think I got the directions for mine after the dealer installed it.
Bill
Some of the reprogrammers let you get into the bells, chimes, kind of stuff even things like what speed the doors lock. Just a thought. :)
BTW the other day I was on the ground and started the truck on the third level of a parking garage, kinda kool. I like the horn beeps, scares hell out of the old folks. ;)
I have the Mopar unit and there is a way to do it but I couldn't figure it out by the instructions. Brought it back to the dealer and they set it up for me. I didn't like the horn beeping either.
Mike
· Sleeper in The Making
Plug and play install ? Was it really that easy, or was their some wire soldering and cutting involved ?
Discussion Starter · #8 ·
There was 4 wires to splice and solder. Instructions are very clear as to what wires and where they are located. So no problems.
Now need to shut off the horn. Instructions did not say anything.
I dont know if this works on the ram but I found this on the charger remote start
There's a green wire that goes to the relay box on the passenger's side of the car under the hood. Open the relay box, remove the relay that the wire goes to, then remove the wire, reinstall the relay, wrap the wire with electrical tape, and secure it somewhere under the hood. Your remote start has been silenced.
HEy I did a search and found this might be worth a try.....
Chirp Vehicle Horn when vehicle locks via the keyfob
Factory Setting: On
To disable (to re-enable repeat these steps)
Perform this operation while standing outside of the vehicle
Press and hold the LOCK button on your keyfob
Continue to hold the LOCK button for at least four (4) seconds, but not more than ten (10) seconds, then press and hold the PANIC button while still holding the LOCK button
Release both buttons at the same time
NOTE: This operation also affects the horn chirp if you have OEM remote start functionality installed.
NOTE: If you inadvertently set off the vehicle horn while pressing the PANIC button, you can shut it off by pressing the PANIC button again.
1 - 10 of 10 Posts
