1 - 3 of 3 Posts
Hey there i have a rough idle and already replaced my spark plugs. Im trying to figure out if its my coil packs but cant find the tolerance values. Anyone know how many ohms theyre supposed to be at? Also I have a really strange issue with it dying out.
More and more often when I go to start it it kicks over and then as soon as the RPM's normalize the truck dies. The electrical power is still there, but the engine needs me to give it some steady gas to pull through. Never dies on the road. Also the security light begins blinking... dumbfounded...
If you were getting a misfire on a cylinder, an error code would show. Try and clean the throttle body, that can cause rough idle and stalling. A vacuum leak would cause a stall too.
1 - 3 of 3 Posts
