Chrysler Knows about it, and only people who filed with NHSTA before case was closed are being fixed the rest of us 300C,Charger and Magnum 5.7-6.1 owners are SOL. go to NHSTA and file a report if you have this problem.
Date Investigation Opened: MAY 09, 2013
Date Investigation Closed: FEB 10, 2014
NHTSA Action Number: PE13016
Component(s): FUEL SYSTEM, GASOLINE
All Products Associated with this Investigation expand
Details close
6 Associated Documents close
Manufacturer: Chrysler Group LLC
SUMMARY:
During PE13-016, Chrysler identified a condition in model year (MY) 2005 through 2006 Chrysler 300, Dodge Charger and Magnum vehicles equipped with 5.7L and 6.1L 8-cylinder HEMI engines that may result in engine stall after refueling when the vehicle is stopped or travelling at low speeds. According to Chrysler, the multifunction control valve (MFCV) fuel shutoff float integrated into 19-gallon fuel tanks can swell in a stuck open position allowing an overfill condition. This condition causes fuel to enter into the purge line which may result in engine stall after refueling. Chrysler's investigation determined that the problem was related to dimensional changes/swelling of the float when exposed to fuels with high ethanol content. Chrysler and its supplier, Stant, developed new fuel soak test requirements to address the condition and extended the warranty period on 19-gallon fuel tanks to lifetime coverage. The owner letter mailing began in January 2014. See the investigative file for copies of Chrysler's owner letter. The Office of Defects Investigation (ODI) analyzed 1262 complaints related to engine stall that were provided by Chrysler or submitted to ODI from consumers. In total, there were 299 unique reports indicating that the fuel system allowed an overfill condition after refueling, and the predominant failure mode identified involved stalling when stopped or travelling at low speeds. The complaint counts shown in this resume include incidents in which enough detail was available to verify the symptoms were related to the defect condition identified by Chrysler. The condition that is causing the majority of stalling incidents in the subject vehicles occurs at a stop or low speed and allows the vehicle to be restarted immediately. The condition represents a low risk to motor vehicle safety and is adequately addressed by Chrysler's extended warranty. This preliminary evaluation is closed.
http://www-odi.nhtsa.dot.gov/owners/SearchResults
Just found this thread on here and saw that only people who filed a complaint can get help?? Is this true? Do we contact Chrysler to complain?
I call my State Attorney General. After they got involved, I got a call from my dealer saying Chrysler said to fix my car. This Monday got a letter from Chrysler saying car fuel tank is now covered for life.
If you are experiencing a symptom/condition related to the technical service bulletin 14-002-14, the dealer can be contacted to verify if your vehicle is eligible for the X53 extended lifetime warranty extension. Letters to affected customers are being mailed.
TSB 14-002-14
SUBJECT:
Engine Stall Immediately Following Fuel Tank Fill-Up (X53 Lifetime Warranty Extension)
OVERVIEW:
This bulletin involves replacing the fuel tank with a revised part.
MODELS:
2005 - 2006 LX 300/Charger/Magnum
NOTE: This bulletin applies to vehicles equipped with a 19 gallon fuel tank (sales code NFK).
SYMPTOM/CONDITION:
Some customers may experience an engine stall condition just after filling the fuel tank. The integral mulit-functional control valve may allow liquid fuel to enter the evaporative emissions system causing a rich fuel condition when the purge system is initiated.
TSB 14-002-14
SUBJECT:
OVERVIEW:
MODELS:
SYMPTOM/CONDITION:
I just a got a letter from Chrysler on Friday about this. Finally!! It stalls every time I start it up now.
