1 - 2 of 2 Posts
Hello thanks for the add to your forum.
remote started truck ended up burning a bunch of wires under the dash. Local repair shop fixed and replaced a couple relays. Said battery and starter need replacing. Took truck. Had a few times truck would barely turn over before starting. Replaced battery and starter. Had issues. Replaced battery and starter again with different same issue. I happen to do a load test on the battery the. The truck started. Turn truck off and the starter only clicks. Do a load test and truck starts fine. So after one start I have to do a load test in order for it to start a second time. This one has me standing out in left field. Local shop was saying something in trans that makes it think it’s in gear. Ok I understand that but why start after load test?
1 - 2 of 2 Posts
