It should be obvious but in case there's that 1 person who goes "what years your truck" its a 2003 which is why im posting in 3rd gen. And im positive this doesnt make a difference but it is a 4.7L
not very happy with the headlights on my truck so rather than buying aftermarket headlights im looking to wire 2 of my off road lights to my high beam.
My current set up is 4 off road lights on the bumper all run to 1 switch. I am looking to have the 2 middle lights turn on with my high beams so i wired a relay to the 2 middle lights and put a diode on each light between where i spliced in the relay and the switch so the other 2 lights do not turn on. Now all im left with is figuring out which wire for the trigger. I tried using the high beam wire between the headlight module and the bulb itself but since i have DRL's the 2 lights are always coming on when i start the truck. So i need to find which wire behind the dash i can use, i tried to locate the wire that controls the highbeam led on the dash but was unsuccessful. I also tried to figure out which wire off the blinker/wiper switch comes active when the high beams are on but again was unsuccessful. Hoping someone can help me out and tell me which wire i need to splice into. I need a wire that is active only when high beams are on that are not part of the DRL's.
Thanks!
Thanks!
