1 - 2 of 2 Posts
Hello, everyone
This is my first time in this forum. Hope someone can kindly help my problem.
two wks ago, I added one full bottle of fuel injection cleaner fluid into gas tank and filled up with 87 gas. after about 150 miles run, check engine light on and stay ever since.
I did the on-off trick to read the error code. first one is P1282 and second is P0456. Could anyone tell me what does it means?
I found from previous post that
P1282 Fuel Pump Relay Control Circuit or
P1282 Accelerator Pedal Position Sensor 2 Low Voltage
P0456 Evap Leak Monitor Small (0.020) Leak Detected
Any suggestions of how to fix it?
Thanks
You might get more replies posting in the Neon/SX forum. This forum is dedicated to the SRT-4, which has an entirely different engine than your car.
1 - 2 of 2 Posts
