I'm going to be Lifting the D this weekend and I just wanted to get some input before going into it. I know after reading that most recent thread that some people think the body lift is easy and some think it's hard. It seems that 2001 to 2003 are the hard ones so I guess I'm screwed there. What exactly gave you guys a hard time though? Were the bumpers the hardest part or was it actually getting the lifting blocks in under the body? I have the electronic dash mounted T-case control so I don't have to worry about that... Also, the TS lift seems pretty straight forward but is there anything I should look out for? You just swap out the rear shackles and crank the torsion bars 8 full turns correct? I have a shop and any tool I will need so I have no problems there. Thanks for any advice you can give:cheers:
Dan
Dan
