Hello,
2 days ago, my check engine light came on. It was a hard code since it came on immediately as soon as you started the van, even cold.
Then........
My van was driving along yesterday morning just fine (with the light on). Suddenly, it started making a whining noise along with the transmission acting as if it were in neutral. I rev the motor and nothing at the trans happens, except the whining speeds up. If I rev way up to 3000 rpm, the trans would limp forward slowly. This is how I went 5 miles to my boy's daycare and left the van there all day.
After work I went to see if it would move or if I needed to tow it. I started it and it drove just fine. No indication that the problems earlier happened. So I decided to drive it home.
I got 5 miles and it started again. Now I needed to go 15 miles and it is all rush hour traffic and back roads. I would stop at lights and it didnt want to go again. Finally after reving it up, something inside would seem to connect and it would jump forward and drive fine for a very short while. Then back to a neutral feeling and i would coast to the next stopping point.
Finally, no more going forward. I was 3 miles from home so I towed it the rest of the way with my truck.
Now today after all day at home in my driveway, I start it and it moves just fine again except for the whining is very loud. It was quick before it would not move again. Fluid is still clear.
The whining sounds like a power steering pump that is dry.
I just bought a scan tool for OBD-II. I get 8 codes:
P0700= Transmission Control System Malfunction
p0732= Gear 2 Incorrect ratio
P0733 Incorrect 3rd Gear Ratio
P1782= Transmission solenoid pack needs to be replaced; P/ES Circuit Out Of Self Test Range
P1788 Pressure Control Solenoid “B” Open Circuit
P1784 Transmission Mechanical Failure - First And Reverse
P0500 Vehicle Speed Sensor Malfunction
What does this all mean? Is it the speed sensor? Pack? Solenoid B? Entire Control Module? I know the trans wants to work. It seems to not be able to.
Thanks!
Then........
Thanks!
