1 - 2 of 2 Posts
Hi I've recently bought a 2001 2500 Cummings and I cannot seem to find any lifts, leveling kits, or body lifts, as i have a 2wd not 4wd. If anyone has any advice that would be appreciated. Keep in mind I am on a highschool budget as i only have a part time job. Thanks
******* SPACESTATION
back when I had a 2wd I used coil spacers in the front and blocks in the back.
You can get up to 4" of lift in the front using lifting spindles with the coil spacers.
Be warned: the ride will be harsh.
The coil spacers are basically metal donuts that go above the coils in the front, they are usually less than $100 for a set. You can get a set of cheapo rubber ones from JCWhitney for $20.
Blocks are also cheap, if you tow make sure you get metal/steel and not the aluminum ones.
1 - 2 of 2 Posts
