1 - 2 of 2 Posts
Does anyone know if the 2nd gen 1500 sports have a removable wheel bearing or do i have to replace the entire hub assembly?
When i go over any bumps with the windows down i hear kind of a klank sound, i have checked and replaced most of the front end it only does it on the front.
Kilroy
going to toss it out there but are you sure your front shocks are tight, especially the upper nuts?
had this issue on the right front of my 97 ram sport years ago and chased it for weeks,
even replaced the outer right front axle u-joint to no avail.. found upper nuts on shocks while
tight werent tight enough which allowed the shock to move causing a metallic thump on bumps
1 - 2 of 2 Posts
