1 - 3 of 3 Posts
The Wife's 2000 GC doesn't have left turn signals. Everything else related to the Turn signal switch (Right TS, 4-ways, Windshield washer and wiper, Hi-beams, etc) works. I changed every bulb in both turn signals, still no LTS. So I ordered a new multi-function TS Switch. STILL no left signal. Any ideas? BTW, for a while, the left signal would work briefly if you worked the 4-way switch on and off rapidly, but now that has stopped working too. I don't think its a ground, since the brake and 4-way lamps work. Flasher circuit maybe? :giveup:
Discussion Starter #2
Come on, NOBODY's had this problem except me?
Have you tried tapping on the combo flasher module on the under dash fuse block? If that goes intermittent remove it. Remove the cover then reflow the solder connecting the external contacts to the internal circuits. The solder often cracks opening the circuit. Very common fix for dead or intermittent turn sigs.
1 - 3 of 3 Posts
