1 - 2 of 2 Posts
Long story short my truck has been having a problem with a cylinder 5 missfire after pretty much trying everything I’m down to troubleshooting the injectors so I was wondering what would be the best injector for it I’d like to get my hands on a set of performance injectors that can support up to at least 500 hp and I kinda want too steer away from oe as I plan do a build in the future
the injectors that r 4 500 ponies won't react well with stock engines. If you suspect an injector of being bad, try swapping it around n see if it follows the injector or not. If it does, then either clean the injector while you got it out or replace it individually. 500 hp injectors will allow flooding of a stock 360 engine cause they're designed for substantially higher fuel flow.
1 - 2 of 2 Posts
