awesome, do you have any pics of just the 2" with 33's?you CAN do the 33's you will have to trim your bumpers.. i ran 33's that i had with 1/2 - 3/4 tread with minor trimming for half a year then i bought new tires and tried trimming more but then i eventually got tired of hearin it rub and did a body lift..
i've never been happier with the 33's and t/s & body lift.. but if your only gonna do the t/s u might want to stick with 32's
hahaha you guys are just now rubbing on the inside of the rear fender?!?!?! lol i get that with my 31's with the 2" t/s lift lol, i like to flex it out going through trenches and crapWhat are "aal's"? Yes, I have the same scrub marks on the inner fenders in the rear but It looks to be rubbing near the center of the sidewall, not near the tread, and it's not bad at all. I've put 60,000 miles on the 33's and there is no noticable wear on the tires. Assuming the 35's your thinking about are the same width as your 33's it shouldn't be a problem. I haven't looked to see what's behind the plastic wheel well but it may be able to be removed as well. Haven't looked into that yet. You could also go with a 34X10.50 tires. Super swamper makes then in the LTB series and they are dirt cheep too. I like to wheel in the snow tho and I want the width, skinny tires dig in the snow.
Mine flexes more then that. That tire still had grip, I think it would have gone more.![]()
Durango's flex? Could have fooled me. That is as "stuffed" as I could get the 33's
Yep that is what I was going to say! The 3" body lift will make the difference! But if you look at the rear spring, mine still appears to be bent alot more then yours.That's weird. In your picture the top of your rear tire is nearly level with the bottom of the wheel well, whereas mine still had several inches to get to that point. I wonder why yours droops farther than mine. Mine would not go any farther. That tire is about 12" off the ground and antho it's hard to tell in the photo I am at nearly a 45 degree angle with the ground (About to tip).
Ahhh, wait. I just read your signature. In my picture I do not have the 3" body lift, just the T/S lift. Your not flexing more than me, your just farther out of the wheel well to start with.
