its a sb standard cab .im looking for straight line measurements.
as in frame length front to rear with out bumpers then centerline measurements for the axles and measurements from front horns to center line for motor mounts . dont need cross measurements ! im making tube chassis for it for mud drag truck . wanting to get rolling chassis done while im still driving it . its hard to get acurate measurements crawling under truck with every thing in the way . local body shops are no help:loud: .... thanks in advance
you might want to hit some wrecking yards to see if you can find a frame you can measure.
+1. ... Or with some basic tools (level/s, square/s, strait edge/s, tape measure, sharpie etc), park on flat concrete floor; transfer what you need down onto floor, mark floor. ... May have to transfer some "along the frame etc", then down onto floor, add subtract as req.
... Good luck, and might consider dropping the REAXXY when asking someones help.
