1 - 2 of 2 Posts
I have 99 dodge ram 1500 with the 5.9l v8. I'm having problems with brake light staying on. Just the two out by the tail gate.theu will come on randomly at any time of the day. since my brake light is staying on its https://speedtest.vet/ draining my battery.i Have already replaced the brake light switch. problem still not solved now my wipers and turn signal work intermediately. All fuses are accounted for. https://vidmate.bid/
Brake lights, turn signals, wipers - all run through the multi function switch. The fact that the center high mount stop light isn't coming on also says it's no the brake light switch.
I'd be checking that MFS out (aka "turn signal switch" due to that being the primary lack of interaction for most people ..)
Just for grins, I checked on WalMart.COM and found https://www.walmart.com/ip/Standard-DS-737-Turn-Signal-Switch-OE-Replacement/137700944
RwP
1 - 2 of 2 Posts
