1 - 3 of 3 Posts
I recently replaced the steering gear box and front end components on my 1998 1500 and now the truck won’t turn right it will turn left all the way but won’t turn right please help.
Sounds like the pitman arm was installed wrong , as if the steering gear was turned all the way in one direction when the arm was attached.
UM I agree but if I remember correctly pitman arm goes/mounts on/at a specific spot--a flat spot on spline from steering box so it CAN NOT BE ROTATED TO a different position---others words pitman arm timed to spline from box---if there's no designated marking you'll have to disconnect arm--rotate steering wheel left and right to establish center then do the same to front end then remount pitman arm--ck this out-------------https://www.google.com/search?client=firefox-b-1-d&q=mounting+a+pitman+arm
1 - 3 of 3 Posts
