1 - 13 of 13 Posts
Its the extra cab. I currently have the 6x9 up front and the 5 1/4 in the rear. I have seen that you can put 6.5 in the front and rear with the adapter plate (or at least they say you can). Has anyone done this? The front depth is 3inches so there are not many 6x9's that will work. The rear depth is 2 inches. I would love to drop in some 6.5. Maybe even components.
Any advice is appreciated.
Thanks
Discussion Starter · #2 ·
By the way...here is my current setup:
1 Alpine 9856
2 10" Ascendant Audio Assassins
2 Clarion 6x9's
2 Clarion 5 1/4's
1 Orion HCCA D2400
1 Crunch 4ch 320Watt
yeah waht bigjoe said, you can use any 1/4" material but as he said plexy works well, I used 1/4" ply wood in my 2001 to fit a set of bostons, just trace your speaker drill out the holes and cut a hole in your new fabed plate where yuo will have the most clearance, It is a good idea to check to see if the wwindow hits the new speaker, then put iut all back together and enjoy...
Awesome...Im going to pick me up some CDT 6.5 Comonents...cant wait to get them installed! Thanks alot.
Do you have any pics? What models did you use and did you cut out the speaker grill or leave it in place?
GROUNDED
leave the factory grille alone its fine where it is, and you dont need a grille on your 6.5" midrange. Im running crystal components in my doors with the 6.5 in the 6x9 spot and the tweeter on that plastic piece at the end of the factory trim by the handle.
Discussion Starter · #9 ·
Sweet...thats what I was checking out today...that plastic trim area is the perfect spot for a tweeter...I take it there was enough room then? Do you have any pics of your setup? Where did you place the crossoverss?
you can also mount the tweeter right next to you r 6.5 in the old hole and keep it close to your mid, I was told that that will produce the best soudn quality, and in my opinion keep the install clean and stealth... Oh, well just my 2cents, GOOD LUCK
******* SPACESTATION
post up some pics when you get it done. I'd like to replace the speakers in my doors as well.
GROUNDED
my crossovers are mounted behind the panel under the lock pin about 7" down. there was a large area there and it fit well.
catman113
i put infinety 6.5s in my rear doors they fit perfectly the 51/4 the store said wouldnt fit 2001 ram quad cab
1 - 13 of 13 Posts
