I have a 1997 dakota with the 3.9. I just bought a 1973 360 engine and 727 transmission. What all will i have to do to make this swap happen? Any help is appreciated this will be my 1st swap ever.
Because it is most likely spam, we got a big rush of stupid all at once about 4hrs ago.Any big reason why you didn't search up a 1997 or so 5.9/360 and the 46RE (727 based OD transmission)?
Jtec?New motor mounts will have to be made.
You'll have to do something for the instrument cluster.
You'll have to rewire the engine bay to get rid of the JTEC.
RwP
Jeep Truck Electronic Controller; the ECU in a 97 truck.Jtec?
Yah, we keep getting that crap at the VS run TCCoA.COM forum I'm a moderator on.Because it is most likely spam, we got a big rush of stupid all at once about 4hrs ago.
If you want 1973 technology, buy a 1973 truck. Seriously. None of your instruments will work, they're servo-driven by the PCM. You'll need to build a custom dash and rewire the truck. Good luck getting the IPM to work without a PCM or body controller. Good luck getting a PCM/body controller to work without expected inputs.I have a 1997 dakota with the 3.9. I just bought a 1973 360 engine and 727 transmission. What all will i have to do to make this swap happen? Any help is appreciated this will be my 1st swap ever.
Yea i decided not to do it now. Too much involved and dont want to lose my guages. So im gonna just fix my 3.9. Gonna put a timing chain in it. Does anyone know if i have to buy a new timing cover or can i use my old one?If you want 1973 technology, buy a 1973 truck. Seriously. None of your instruments will work, they're servo-driven by the PCM. You'll need to build a custom dash and rewire the truck. Good luck getting the IPM to work without a PCM or body controller. Good luck getting a PCM/body controller to work without expected inputs.
It boggles my mind that people think they can tackle "projects" like this.
Ok thank youReuse, just put a fresh crank seal in.
After new timing chain is in do i have to move the distributor any or not? Or just make sure its top dead center and it should be good?Ok thank you
