My 1997 dodge van is having some electrical issues. When cold my distributor is not getting any spark from the coil. there doesnt seem to be any power going into the coil. The other day I installed a new CD player in the van and the problem amplified to keep vehicle from starting at all. after i unplugged the radio the van started. I then wired the radio to the battery via a fuse. now if I turn on the radio the engine belts squeal loudly or the van dies all together. I had the battery and alternator tested and appear to be good. The belts seem tight. the belts will also squeal if the battery has been run down at all (I.E. the van refusing to start and the cranking of the motor to try and start it) So far I have replaced the distributor, plugs, wires, coil pack. I unplugged all of the connectors I could get to from the top of the motor and cleaned them with electrical cleaner and gave um a shot of dielectric grease. after all of that last night the van died on the freeway following a lot of sputtering and backfiring. I am losing my MIND!! This started about 4 months ago right after doing the tune up. I have tried retracing my steps to see if anything was faulty with no success
