1 - 2 of 2 Posts
Hello there,
My truck for some reason when I start it it seems to be idling low along with it stalling in certains spots, a couple times it stalled on the way back to my home. Is there anything in particular that I would need to look at? When it does stall, the only code that throws is the oil light, however the oil had just been changed...
Anything that I should look at to figure out what the problem is?
It's telling you you have zero oil pressure after it stalls/dies. The IAC controls the idle, may be dirty and hung up. Common problem.
1 - 2 of 2 Posts
