What are you talking about N-GIN? Under the car???
To gain access to the shifter bushings on the tranny (two on tranny, two on shifter) simply remove the air intake tube between the airbox and throttle body and unclip the fusebox fromt he battery tray and push it aside. You'll be able to see the bushings where the shift cables attach to the top of the transmission. Pop the cables off the stalks on the tranny, and remove the sloppy stock rubber bushings with a flat tip screwdriver (or they might just fall out/apart, depending on how bad they are). Put some lithium grease on the outside of your new booger bushings ($20 for the set, worth every penny and then some) and on the stalk on the transmission and first pop the bushing into the ring at the end of the cable and then onto the transmission stalk. Repeat this process for the two bushings on the shifter. To gain access to them, remove the center consol (6 screws in armrest storage unit, 2 near the cupholders) and then pop the tabs that hold the boot to the base of the shifter and lift the boot up and hang it over the knob. The bushings will be in plain sight.
When you order a set of booger bushings they come with step by step directions, although the process is VERY simple.
