1 - 6 of 6 Posts
I am in need of some help with my headlights. Both had gone out on Thursday Night. I have been driving myself nuts tzhe past few days trying to figure out what happened. I checked my fuse box under the hood. there is a 50amp fuse that says something like lamp or something. but that was fine. i do not have my manual to locate any other fuses. any help would be greatly appreciated.
Thank you,
Joe
my chiltons manual points to that 50 amp fuse as well...which doesnt help you at all. switch it out with another fuse just to make sure. or get a tester and ground it to your battery and make sure you are getting power to both sides of the fuse.
otherwise maybe the switch is bad?
Discussion Starter #4
Thanks for the reply. I will have to get another fuse. hope that works. i did do a continuity test on it, It had continuity but maybe it is still bad.
Registered MOPAR User
I will deffintetly place my bet on the switch. Have you in the past year changed out your bulbs? The dodge wiring, especially on the headlight circuit is barely enough.
Have you smelt a plastic burning smell recently?
1 - 6 of 6 Posts
