1 - 2 of 2 Posts
Hello,
I have a 94 dodge shadow that has had some work done to it to get it back on the road. It has had the following parts installed;
-fuel pump
-fuel filter
-timing belt
-coil
-wires and plugs
-fan
i have also had the fuel pressure tested and the oil pressure tested and both are fine. the water pump has also been tested and shows that it to is fine as well as the rad and hoses.
my problem now is the car runs for about 5 mins and then dies out for no reason like it's being choked. to describe it accurately it sputters out, but it sounds like it wants to keep going. I have looked up the codes it flashes before but now the only code it flashes is code 12 - battery disconnect, which i tried to no avail. I have looked up various issues with this car and wanted to know if anyone had any ideas on what i need to do to get this thing running without spending tons of cash.
cheers!
Check out the Hall effect sensor. Look at allpar.com under K car fixes.
1 - 2 of 2 Posts
