1 - 2 of 2 Posts
Having a hard time buying new after market upper control arms for my 1993 Dodge Dakota 4 wheel drive. Looks like I can get the two wheel drive arms no problem but not the 4 wheel arms. Anybody has any suggestions I would appreciate it
Trying to get it aligned? Bolts are 9/16.. Not in the books at Dodge. Thought I'd made a note in my FSM about the thread pitch, buy can't find it.. coarse or fine... def SAE. Get the NAPA rusty bolt remover sockets with the spiral teeth to get it loose, the Autozone angular ones are not only too soft, they won't grab. If my suspicions are correct and you want to get alignment, forget the new upper a arm.. It's a junkyard only item and unless it's all bent to hell, you probably don't need it anyway. Good luck.
1 - 2 of 2 Posts
