ANTI SEIZE
Particularly effective on stainless steel bolts and nuts which have a high likelihood of seizure.
A highly refined blend of aluminum, copper and graphite lubricants. Use during assembly to prevent galling, corrosion and seizing and to assure easier disassembly. Protects metal parts against rust, corrosion, and seizure.
Temperature range: -60°F to 1600°F (-51°Cto 871°C). Salt, corrosion and moisture resistant – ideal for marine use. Non-aerosol version meets Mil Spec #907E. Aerosol - Level 3*
Never-Seez
Particularly effective on stainless steel bolts and nuts which have a high likelihood of siezure
Cost wise Never-Seez is a couple $ more.
http://www.meyerplastics.com/adhesives_seal_tape/anti-seize_comp_sht.htm
