Your truck does not have struts ,it uses shocks . It may have had the coils cut in front when they dropped it , which can result in a bad ride. If you want a nice ride go back to stock with some quality shocks .
Well sir,Your truck does not have struts ,it uses shocks . It may have had the coils cut in front when they dropped it , which can result in a bad ride. If you want a nice ride go back to stock with some quality shocks .
Well sir, I have an 88 that I am rebuilding as stock. What little I know, here is what I did to get me a smoother & more stable ride. First off, I'm not trying to get her to drive like a BMW....the truck is a tool so I needed sturdy & have ability to drive 65-70 smoothly on the highway. All moog parts: replaced entire front suspension...including all fasteners & bushings. On the rear,I replaced springs and leafs as stock. All shucks are KYB's. The only new part was that I installed a sway bar on the front that was not part of the original truck. I also use tires that are a little wider & taller than stock....same original wheels though. Good luck
