1 - 2 of 2 Posts
Doing this for neighbor so he can get his wood truck running. It has fuel to inlet filter but doesn't pump fuel thru accelerator pump circuit. Fuel filter replaced. Seems to me that it should show fuel in bore when throttle plates are opened. He is going to do a dry and wet compression but it was a runner a couple of months ago. What am I missing?
Is this a new carb install or what? If the accelerator pump is not spraying fuel into the venturi there is an issue with the pump or no fuel in the carb. Stuck float valve, Plugged up ports, Need to investigate.
1 - 2 of 2 Posts
