On the keyless entry you would need to convert the manual door locks to electric, not a hard task. This would give you something to hook the keyless entry to.
Alarms are pretty much straight forward. Not hard to install. Finind the right waires to disable the ingition would be the hard part.
The remote starter is the tricky part. Your truck probably has a convention carbs with an automatic choke. These chokes are set by pressing the pedal down and releasing itThis rotaotes the high idle came inplace as well as closing the choke. It also give an extra squirt of fuel. If you added the remote start you would have to setr the choke when you leave the truck everytime you leave the truck. Even then the remote start may not start the truck.
Converting from the carbs to an electronic fuel injection would cost a fair amount but would siplify the starting isuues.
What you want can be done it just may take a bit of cash to get it all to work well.
Leo
