When I bought my 1974 D200 it came with only one key. It has a pentastar-shaped bow (the part of the key that you hold in your hand) and fits the ignition. It does not seem to work in the doors but the door locks are likely frozen because I can't operate them manually with the inside lock plunger either. I had a 1974 Dodge Coronet and it had a pentastar-shaped key for the ignition and a round key for the door/trunk/glove box. Do 1974 trucks use the same 2-key system as the cars or should the ignition key for my truck also operate the door locks?
Thanks,
Scott
Thanks,
Scott
