I'm doing prep work on a '73 Kary Van before painting and will need to replace the seal between the cab and the box, the one that goes bottom left behind the driver's door up across the top of the cab and down the other side. It's a quarter round shape with a tail to fit inside the gap between the two sheet metal pieces. Does anyone know if there's a replacement? A good place to find something that would work? Or maybe a alternative way of sealing? Maybe seam sealer with a L-shaped gasket glued on?
In the meantime I'm cutting and patching the rusted areas above the cab. What a dumb design Dodge did there. Multiple stiffening channels on the roof that don't allow the water to run off so it finds it's way into rivets and joints.
