How Can You Tell What Gear Ratio You Currently Have On A Used 2003 Ram 1500? The Stickers Are Gone, Is There Another Way? Thanks
I Did Not Look In The Glovebox. Thanks. Another Friend Told Me I Could Also Put It In Neutral, Lift A Back Wheel, Turn The Wheel One Rotation And Could The Number Of Times The Driveshaft Turns.
If the sticker in the glove box is gone just go to a local dealer( parts or service should do it )with your vin # and have them print you a build sheet. Should take all of 2 minutes and should be free. Will show you every option and feature that came on your truck. IMO, all vehicle owners should do this and keep it on hand.
Agreed...
I would not recommend the Spinning the wheel thing... Your not gonna be able to get an accurate enough count with gear slack, etc...
Your either going to have the 3.55 or the 3.92
