1 - 6 of 6 Posts
What was the factory wheel size on 3/4 and 1 ton trucks? What is the smallest wheel that I can go with and SAFELY and effectively clear the stock brake assembly and everything else that's needed?
TIA :gr_patrio
EPA's Worst Nightmare
Stock was 16" rim and 265/75/16 tire. I've heard you can run a 15" rim on some rams but others hit the calipers. I can't say for sure since I have never tired it.
Thanks for the reply! If you get bored here in the next couple days and wanted to run to a tire store in town that had a 15" wheel in stock..... just to see..... :D
I'm thinking (hoping) that the 15" wheel size is the same deal with the 1/2 ton's. Everyone said you can't run 15" wheels because of the brake system. I'm running 15" steel wheels now. I can't see the alloy 15's working, they're thicker.... but the steelies work just fine.
Got my fingers crossed!
I would think the alloys would work. How much thicker are they and how close are the rims you currently have to hitting?
I bet his reason is he can't get the tire/size he wants in a 16" rim size.
1 - 6 of 6 Posts
