1 - 2 of 2 Posts
My truck was at the shop and I had them change the lower control arm Cam bolts, and line up the front end, Well they only changed 1 cam bolt and could not line it up.
So now I cannot turn the steering wheel while sitting at a stand still, (I could before it went in ) It seems to be binding. If I jack up from the axel it turns with no problems ( no weight on it ).
I did measure from the rear wheel to the front on both sides and the passengers side is longer by 3/4 inch. I tried to set the cams but no luck on removing the bind.
I have a 95 Ram
4 inch TrailMaster suspension Lift
35 x 16 MT baja claws
Discussion Starter · #2 ·
Well I spent all day working on the steering, and got it fixed.
After changing the gear box (warrenty). steering pump, and 2 lines.
The aligniment is out. I have new bushings for the lower arms and new cam bolts comming in on Monday,
But the bearing for the steering brace may be bad, it moves ok when not installed but once it`s on it seems a little tight. I`ll look it replacing that soon.
1 - 2 of 2 Posts
