Spark will zap once then stop, zapped twice in same second once. cam and crank sensor are energized even with key off checking outside wires the center wires energize when fuel pump runs 4.9v cam sensor batt voltage at coil. fuel pump runs then stops when key turned to on. Pump runs when engine cranking. New crank sensor. Coil and cam sensor checked by swapping used parts.
