21 - 40 of 40 Posts
Chad, you tint lights as well right? how do you think these halos would look with tinted tails?
...are these halos ccfl?
Varooom !!!
Will these be available in Carlisle? In smoke?
Hummer Recovery Vehicle
Discussion Starter #24
Derty - working on a nice clean diagram for you still!
Yes, we can tint the lenses, and they will be available at Carlisle.
Discussion Starter #25
Here is a start. Some good info in here, but no diagram:
http://www.dodgetalk.com/forums/showthread.php?t=238194&highlight=tail+light+wiring
I talked to the manufacturer today. I had thought they had a conversion diagram, but they do not. I will continue to try to work on one for you.
I can tell you that the easiest way to convert will be to use a test light to find your ground, running light(+), brake light (+), and turn signal (+), and then use t-taps to tap into the existing harness. If we were doing the install, we would splice/solder, but t-taps are just as effective.
Again, we will continue working on a diagram for you, but it is difficult not having an 02-06 ram with us.
can we see pics from 15-20 feet away at nite ??
Discussion Starter #29
its canied, we can do the same!
halo tails
see i need to look on here even more. these tails are very nice looking. seems i might be doing some bling instead of performance.... so these are plug and play for 07-08's? no lamp out warning etc...? thanks
Discussion Starter #32
that is correct, just tap into your running light wiring with the inverters on the back side of the housing, and you're set.
tail lights
so i take all parts are included to do this then? thanks again
Discussion Starter #34
yes they are. in fact, we have a core set you can buy if you're interested. fully installed. let us know!
tail lights
can you post or pm me the price? need to see where i am at being this close to x-mas and all. might have to wait till the 1st of the year. thanks
never mind, re-read the cost with core. thanks
Discussion Starter #36
we have a spare set we'll let go cheap if you're interested. competition wants 200 just for the rings, shoot us a pm and we'll get you a great price.
Halo tails
Hey chad, I have a 2002 ram 1500, I saw you said that they would fit with slight wiring changes, if I want some, where do I go to order and do y'all ship them with the wiring changes already done and exactly how much would I have to spend with the kit, taxes, shipping, etc.?
Discussion Starter #38
Hey there, you have your choice between CCFL and LED halo kits now, i would recommend the LED, but i can also supply the CCFL. PM me with which kit you prefer and i'll get you pricing.
As far as the wiring, i believe a member on here (Demon-Hemi) sells the wiring, or i believe he used to. He would be your best bet.
Thanks,
Chad
21 - 40 of 40 Posts
