1 - 20 of 30 Posts
ok guys, i had a feeling that the srt10 push button was alot easier to do in the 06 trucks. I had an 05 and went throught hell getting the parts. I googled a vin for a 06 srt-10 and called me dealer. the only parts you need is the switch which is 35 bucks and the bezel which is a small square that replaces the blank square in the left of the lower radio bezel. i have 50.00 in the parts. I am having a problem wiring the switch in, I have an slt w/ remote start. has anyone been able to make a push to start work in the 06? if so where did you connect the wires. i get a click from my starter, almost like there is not enough power to turn it.
THANKS
SNKX
Yea, It's a Hemi
just buy an srt 10 :p
THANKS
SNKX
Welcoime to DT shadow! Glad to see another Mississippi brother on DT. I know there are tons of posts on the SRT start button, but I honestly havent seen much on the 06 specific application.
What do you do in Laurel? Ever make it to Jack-town?
reply
I think I did it to the purple brown. I will try the other! Thanks
That is the wire I have it on. Still not working
IGNITED PERFORMANCE Buttons fir right in the cig lighter
Discussion Starter · #9 ·
reply
I prefer the look prefer factory over aftermarket
Discussion Starter · #11 ·
the wire is green with a yellow marking. When i push the switch it just keeps clicking............. untill i release it.
Member
One side if the start button needs to be a switched power source and the other side if the switch needs to be the starter wire. I suggest T-Taps. That way you do not need to cut any wires. I do not know which color the starter wire is that is located in the harness underneath the steering column.
Yea, It's a Hemi
Im going to be getting one this winter, was wondering if paint thinner can remove the text above Engine Start. Does it seem like it can uncbob?
Discussion Starter · #16 ·
parts
3D7HA18H66G269131
give this vin to your parts guy, tell him u need the bezel and the push to start switch. no wiring. the bezel you need is square (where the blank one is in your dash. sorry I just moved and I have misplaced ther part nums.
Member
It might, but I don't think the plastic will look as good. I think it will dull it. Plastic does not react well to paint thinner.
I highly doubt it but I haven't tried it
Yea, It's a Hemi
hmmm I will have to figure out something....
1 - 20 of 30 Posts
