1 - 7 of 7 Posts
Does anybody here have any experience installing the rear hatch release button inside your Magnum? Probably doesn't have to be a magnum I would imagine they're all close to the same but any tips and tricks and advise appreciated!
Yeah it looks like there's an existing harness there ready for the button switch and that's exactly what I'm doing I'm searching Google and YouTube as well!
Red Trucker
There is, just because of mass production and platform sharing. Problem you'll run into is that the factory remote release is routed through the cluster; since the Magnum was never built to have this, this provision isn't there. You can't use the factory harness unless you switch to a Charger or 300 cluster (or run your own wiring). As I recall a resistor is also needed. Good luck!
1 - 7 of 7 Posts
