THIS POST HAS BEEN MOVED TO THE CORRECT FORUM.
List,
I've got an Anti-Lock-Brake (ABS) system fault light at the dashboard in our van.
Questions:
1) Does anyone know if there's a secret sequence (IE. switching the key on and off for x amount of times..) the owner can do to retrieve the fault code? (Assuming it exists. I'm trying to determine which axle sensor is causing the fault without having to go to each wheel.) (I'm told Autozone's scanners cannot retrieve wheel/axle specific information)
2) Does every Dodge vehicle have the capability to display error codes?
List,
Questions:
