Hey. My 2004 Dodge Stratus ES 2.7 V-6 started stalling on me about 3 months ago and the check engine light came on. The car runs for about 5-10 minutes and then it will just stall as if it shuts off. No warning at all. I brought the car in for a diagonostic (cost me 88 bucks) and they told me that it needs a tune up because the cylinder 3 spark plug needs to be replaced and is causing the car to misfire. The pcv valve and air filter needed to be replaced. The map sensor needed to be replaced and there is an open flash that needs to be done (computer software upgrade).
Does any of this make sense? The car is out of it's 3/36 warranty. Are they just trying to get my money?
I replaced the pcv valve and air filter for less than 20 bucks and did it myself.
What does the map sensor do? If I do the tuneup, which involves replacing all the spark plugs will this correct the problem or will I still need a new map sensor.
The car only has 31,000 miles.
Any help and ideas would be great. Thanks...
