I am considering using nothing but synthetic oil in my '05 Hemi D.
Any thoughts??
Any thoughts??
Thanks for the input...HemiEd said:Wow, you should get tons of opinions on this one! :blah:
I personally have used Mobil 1 5W-30 synthetic since my first oil change. I have used Mobil 1 in many vehicles have never had a problem. Other people like Amsoil, Royal Purple and so on. I use Mobil 1 because of I can find it at any Auto Parts store and it works well.
Here's one that will spark some debate alsonice:
What kind of oil filter do you plan to use? Again this can be argued, but I use either a Purolator Pure One or Mobil One filter. Check the boards and you'll find many threads with more info on this subject. Good luck!
I'm with HemiEd, I use the same....except I use the 10W30 as I'm in Atlanta and that's what my other 2 turbo cars use. Anyhow, I put 285K on a turbo talon using Mobil 1...and never had any engine or turbo issues...and the car is still running, a friend of mine bought it for his son. If Mobil can protect a hot running turbo 4cylinder, it sure can take care of a NA V-8.HemiEd said:Wow, you should get tons of opinions on this one! :blah:
Just about all of the major oil manufacturers make 5W-20.Big3 said:5w-30 maybe? I don't think anyone makes 5w-20...
Just as an FYI...Big3 said:Thats TSB only relates to some of the 2005 Dodge models, that is why I didn't have it referenced in Infotraxx.com for my 2004. 5w-20 seems a little thin (like qualifying oil back in the day at Daytona).
