1 - 3 of 3 Posts
I have an 03 ram 1500 5.7 . 2 months ago, I replaced fuel pump, regulator and all filters. My 02 sensor white wire came off which I repaired. For 2 months everyhing was fine and one evening after work, I was driving home and the engine started to miss. I saw the fuel pressure drop to below 40psi and made it home. So far, I replaced the pump which had no effect. I found a vapor line from tank to cannister off -re-connected but no effect.
02 sensor is new and everthing looks good. Fuel pump relay good, voltage to everything good. Tried clearing codes and diconnecting batt- still not right.
If you have any advice, I sure could use your help.:ugh
ever change the plugs?
03 ram 5.7 won't start
plugs are good. I've read to change the cam position sensor but not sure where it is??The truck was running fine then all of a sudden this prob. started.
1 - 3 of 3 Posts
