Its seems as if my front end is sagging. I can pull up next to an identical 03 and theres sits about an inch or two higher. everything is stock for now but the time is coming for a lift and few other items.
can i go with a taller tire to get a bit of ground clearance?
03 SLT 2x4 4.7l
255x65x16
· Patriot....
welcome to DT. ARe you sure that the D you pulled up next to is a 2x4?
BTW, it's 4x2 , and as indicated above, a 4x4 is about 1 - 1 1/2" heigher than a 4x2.
positive it was a 4x2 even looked under to see if it was a 4x2.
