1 - 6 of 6 Posts
I've got a 03 1500 4WD 5sp Manual with 80K miles that will go from 2WD to N to 4WD Hi and back with no problems but it will not go into 4WD Lo. Iv'e checked the linkage...no binding or obstruction. I've never had it in 4WD on any hard pavment, and it worked in 4WD Lo just a couple weeks ago while in my yard.
Any ideas??
try putting the truck in Neutral and letting it roll a little bit (a really little bit and then stop) while you try and slide it in?
Turn the truck off while in neutral and it should go right in
voo doo 1 I am buggin out
get the truck rolling about 5mph and step on the clutch and place the shifter in neutral then try to shift the transfer case to 4wd lo ...... do you get any grinding or it just doesnt want to shift .... if it grinds I would say you got some synchros hosed but if it gets stuck and doenst want to shift then maybe turn the truck off and rock the shifter thru all the gears .... 4HI N 2HI and 4LO to make sure it is smooth .. if not you may have to take it in for service.
sans sanity
I'm assuming you have the manual 4X4 shifter and not the knob.
Do you get the grinding that is typical?
1 - 6 of 6 Posts
