Hello all!
I have a 02 1500 4wd with 9.25 rear and 3.55 gears. The pinion nut came loose at 65mph, that dropped the drive shaft and allowed the pinion gear to get sucked down in to the diff - creating a hole in my rear diff. Now I need a new housing. Part number 5072511AA is discontinued for the 2002.
The 2005 axle housing appears to be part number 5072511AD and it is in stock.
I've checked my local scrap yards. No luck. Re-manned ones for mine are running $1,300 to $2k which is ridiculous.
Does anyone know how difficult it would be to get a newer axle assembly under my truck? New, they run roughly $600-$700 (just the housing).
Lastly, it appears that this pinion nut issue is not as rare as it should be. There was a recall for the 05 models for it.
EDIT: I just looked through all of the parts for the 2002 and 2005 rear axle assembly. The only parts that were different part numbers were the housing itself and the wheel studs. Everything else - pinion gear, gear sets, yoke, shims, bearings, seals, etc. - were the same part number. This suggests to me that everything can fit in/on either axle housing. But something about the housing casting is probably different. But likely not anything that would keep it from working. Your thoughts?
