1 - 6 of 6 Posts
I'm looking at buying an '02 or '03 Durango (4.7L). I want the 3.92 axle to give me the greater towing capacity, but I read somewhere that this was an option and not the standard (which is 3.55). Is that true? Will it be hard for me to find a 3.92 axle?
I also read somewhere about someone who mentioned changing it. Is that realistic? Can you change a 3.55 to a 3.92 with a reasonable effort? How many hours would it take a Dodge mechanic to do that?
Thanks,
d
Pimp On Sir Don
I don't know that you'll have TOO much luck finding a 4.7L with the 3.92's. Any R/T has 3.92's, but they also only have the 5.9L only.
I would think the only 4.7L's you would find with 3.92 gearing are going to have factory tow packages as it was not standard. however, the gear change was standard I believe with the factory tow package.
You wouldn't probably want a dealer to do your gear changes as I doubt they do that very often. A good offroad shop if you have one in your area would be a good place to start. Ask around, you'll find someone that people keep on referring to (positively I would hope...) With 4WD expect to pay about $1200 for gears and labor. While you're at it you may as well get 4.10's and not 3.92's if you're going from 3.55's.
WORLD'S GREATEST TRUCK
If you're concerned about towing capacity, at least start out w/a D with the factory tow package.
The 3.92 was a seperate option on the order sheet in 99. I don't have tow package so I am not sure if it is also part of it also. Ye the gears can be changed but it will cost (depending on where you go) between 800-1500 for both axles if you are looking at a 4x4.
Oh yeah, if you swap gears you need to reprogram revolutions into the CAB
1 - 6 of 6 Posts
