Been a few years since I've had an old Dodge - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 7 Old 03-27-2019, 04:46 PM Thread Starter
rockabull
rockabull's Avatar
Quoted: 1 Post(s)
It's also been a few years since I've been on Dodgetalk, props to whoever sent me three password resets on my account, since I don't think the email I signed up with is even active anymore.
I'm picking up this 1984 W-150 this weekend, sans the plow. No idea on miles, but it's a /6 truck that runs, and it's not in the $3-4,000 or more price range these trucks have been going for in CT. That's right, people are asking over four thousand dollars for 30+ year old plow trucks in the rust belt.
Plans are to clean it up and use as a daily driver, eventually I'd like to move up to a 360 o a big block, but that'll have to wait until I save some money and can take time off to do the swap.
Forgive me Dodgetalk, for I have sinned!
I am now driving a 95 f-150, and the worst part is I let a shop do some work on it!
rockabull is offline
Quote Quick Reply
post #2 of 7 Old 03-30-2019, 02:01 PM Thread Starter
rockabull
rockabull's Avatar
Quoted: 1 Post(s)
Got the truck home finally, here's some more pics, the carb close-up is an extra that came with the truck.
The fuel tank was a gas can in the cab with an electric inline pump to prime it, and it takes a bit to get it running. Doesn't like to stay running when it's put in gear, though.
Suggestions on where to start? I'd like to get it road worthy first and foremost.
post #3 of 7 Old 04-01-2019, 12:21 AM
reek
Quoted: 12 Post(s)
looks like a fun project. I grew up with slant 6 dodges. Our family had a 70 dodge dart, 75 duster, 80 aspen, 79 D100 all with /6 motors. I now have a project truck with a /6. if you can find parts, I'd start with a complete carb rebuild.
I'm taking the pansy way out. I'm getting a magnum 5.9 EFI build for the truck.
reek is offline
post #4 of 7 Old 04-03-2019, 05:16 AM
Ray Bell
Though it's not a 4 x 4, here's a good tale about my slant 6 pickup...
http://www.moparmarketforum.com/foru...p?f=32&t=28084
Ray Bell is offline
post #5 of 7 Old 04-05-2019, 07:52 AM
Ray Bell
Hmmm...
Got a strange message and posted again. Sorry...
Ray Bell is offline
post #6 of 7 Old 04-05-2019, 07:54 AM
Ray Bell
Well, you wouldn't want to get your hands that dirty, would you?
And I'm not sure if that model had the 7-lug wheels. If that is the case, then you got everything you deserve!
Hope you enjoyed looking at my slant 6 story...
Ray Bell is offline
post #7 of 7 Old 04-28-2019, 02:51 PM
txwooley
Quoted: 111 Post(s)
I think I'd start with the gas tank. Find out why PO wasn't using the original tank and decided to put a bomb in the cab instead. While you are addressing that safety issue, a rebuild kit for that carb would be a great start. You might be better off trading that to a parts house for a reman with a waranty.
After rebuild/replace the carb tune everything. Set your carb idle mixture and idle speed then set timing with the vacuum advanced unplugged.
Give a good look at all vacuum lines. They could by dry rotted and cracking or broken causing a vacuum leak which will cause stumbling, rough idle and die when put in gear.
J.T. Wooley
txwooley is offline
Diode Dynamics: SL1 LED Headlights for Dodge Ram! USA Made! See Install Video! Diode Dynamics Diode Dynamics 13 06-04-2019 11:26 AM
Rims for 2008 caravan....question Brendak 5th Gen Caravan Talk (08-Up) 0 09-23-2016 08:10 PM
Diode Dynamics: Dodge Charger Reverse/Backup LED Bulbs! Plug & Play Install! Diode Dynamics Diode Dynamics 1 07-07-2016 09:00 AM
